English
Microsoft does not provide new Shell versions anymore. That is why Beckhoff has introduced TcXaeShell. This is a Visual Studio Shell 2017 labeled by Beckhoff. It can only be installed together with a TwinCAT setup and not separately afterwards.
TcXaeShell is supported by Control plus Studio V5 and OES V4.10d and newer.
If you have projects with versions older than OES V4.10 you can download some old Visual Studio Shell versions here or ask our Nexeed Helpdesk:
https://visualstudio.microsoft.com/vs/older-downloads/isolated-shell/
Visual Studio must be installed before TwinCAT setup.
Recommended setup order:
Isolated Shell
optional: Language Pack Isolated Shell (e.g. for German Visual Studio)
Integrated Shell
optional: Language Pack Integrated Shell (e.g. for German Visual Studio)
TwinCAT setup(s)
TcXaeShell can only be installed together with a full TwinCAT setup. If you have already installed the latest full setup, you have two possibilities:
Wait until Beckhoff releases a new TwinCAT version and activate the checkbox to install TcXaeShell together with TwinCAT.
Uninstall the latest TwinCAT version and install it again.
Deutsch
Microsoft stellt keine neuen Shell-Versionen mehr bereit. Deshalb hat Beckhoff TcXaeShell eingeführt. Dies ist ein Visual Studio Shell 2017, gelabelt von Beckhoff.
TcXaeShell wird unterstützt von Control plus Studio V5 und OES V4.10d und neuer.
Bei Projekten mit Versionen älter als OES V4.10 kann Visual Studio Shell hier heruntergeladen werden oder unseren Nexeed Helpdesk kontaktieren:
https://visualstudio.microsoft.com/de/vs/older-downloads/isolated-shell/
Visual Studio muss vor dem TwinCAT Setup installiert werden.
Empfohlene Installationsreihenfolge:
Isolated Shell
optional: Language Pack Isolated Shell (z.B. für deutsches Visual Studio)
Integrated Shell
optional: Language Pack Integrated Shell (z.B. für deutsches Visual Studio)
TwinCAT Setup(s)
TcXaeShell kann nur zusammen mit einem Full-Setup von TwinCAT installiert werden. Wenn Sie das neueste Full-Setup bereits installiert haben, gibt es zwei Möglichkeiten:
Warten bis Beckhoff eine neue TwinCAT-Version freigibt und das Häkchen zur Installation von TcXaeShell zusammen mit TwinCAT setzen.
Die neueste Version deinstallieren und noch einmal neu installieren.
