1. When I simulated the code scanner, I found that the simulator only supports serial ports, but I didn't find some of its parameter settings, such as baud rate. Does the barcode scanner simulator currently support IP configuration?
About the simulation of the code scanner
The peripheral "NexeedSimulationScanner" simulates both the TCP/IP and serial scanner peripheral.
Because it is a simulation peripheral it does not need the hardware parameters like baud rate or IP address.
In our example project Digital Machine the scanner object is used with a serial scanner peripheral. Because the simulation mode is activated, the serial peripheral is not used/active, but the simulation peripheral:
