This is the answer I got from a colleague from the MES department:
The way of connecting the data also depends on your later usage in MES. For using this kind data you have different possibilities in MES.
- Mostly QualityData is the module which will be filled with this kind of data in order to fulfill traceability
- But you can also use our module Process Quality. This module is optimized for curve data. Please have also a look at this, too.
- Or you can use a condition monitoring. For this we have 2 modules (CMControl and Condition Monitoring)
There are different ways to process such amount of data in MES:
- Via XML message
- A “simple list” as shown in the original message
 This can be used for MES QualityData.  For other modules it’s hard you convert the data into a usable format, since the shown way (below) is only available within QualityData.
- As mentioned from an MES application engineer we need to have the ProcessReal-Arrays to save data, but we have some “helpers” to convert them. So we have 2 choices here
- You can convert them to a ProcessRealArray on station side, using only name, value and datatype (optional). You can skip other not necessary content like limits here.
- This is the recommended way, since you are achieve the highest flexibility in MES to use the data in different modules
 You can use it for QualityData, Process Quality and both ConditionMonitoring modules
 <arrays>
 <array>
 <array name="Station.MesTestingArray">
 <item name="Station.MesTestingArray[1]" value"0" dataType="4">
 <item name="Station.MesTestingArray[2]" value"0" dataType="4">
 <item name="Station.MesTestingArray[3]" value"0" dataType="4">
 <item name="Station.MesTestingArray[4]" value"0" dataType="4">
 </array>
 </array>
 </arrays>
- It is also possible to save the data as a 2D curve.
- This can be used in QualityData only.
- There is a defined structure for this. But there is no “standard” visualization in the web for it. To get this visualized you need a customized view, which needs to be implemented especially to your system. Please check if this can be done, before using this option.
 <structArrays>
 <curve2D>
 <structs>
 <head version="1" name="myCurve" result="0"/>
 </structs>
 <structArrays>
 <array name="axis">
 <structDef>
 <item name="name" dataType="8"/>
 <item name="axisType" dataType="8"/>
 <item name="unit" dataType="8"/>
 </structDef>
 <values>
 <item name="time" axixType="X" unit="s"/>
 <item name="pressure" axisType="Y" unit="bar"/>
 </values>
 </array>
 <array name="characteristicDiagram">
 <structDef>
 <item name="X" dataType="4"/>
 <item name="Y" dataType="4"/>
 <item name="lLY" dataType="4"/>
 <item name="ulY" dataType="4"/>
 </structDef>
 <values>
 <item X="5.0" Y="3.0" llY="2.8" uLY="3.3"/>
 <item X="6.0" Y="2.9" llY="2.9" uLY="3.4"/>
 <item X="7.0" Y="3.1" llY="3.0" uLY="3.5"/>
 <item X="8.0" Y="3.2" llY="3.1" uLY="3.6"/>
 <item X="9.0" Y="3.4" llY="3.2" uLY="3.7"/>
 </values>
 </array>
 </structArrays>
 </curve2D>
 </structArrays>
- As already mentioned you can save them as binary file (e.g. *.csv)
- They can be moved with CyclicUpdate and added to QualtiyData as file as some kind of “attachment” to the identifier.
 This binary file will also be included to the archiving process
- PPMP
