WebView2 generate files when run HMI Locally
Hello All,
We found that WebView2 generates lots of files on STD\Hmi_V5_3\OpCon.HMI.Modulo.exe.WebView2\EBWebView on different subfolders when run HMI locally on CPS.
That is not nice to handle backups. We have to investigate deeply how to ignore those files but looks so creepy.
Could you even help us to check which folders/files we should ignore?
There is no possibility to avoid this file generation or change the location of those file to anothr folder?
Thanks in advance
You can ignore the whole folder OpCon.HMI.Modulo.exe.WebView2.
We will check if we can have WebView2 create this folder somewhere else in future versions.
