TwinCAT settings is missing frequently
Hi comunity,
From time to time, we are facing that many of our colleagues loose the settings that we set previously on TwinCAT settings under VS options, chains, tabs fonts, colors...
Especially the SFC Step implementation and the tabs are miss very often
Did someone face this problem before?
Losing settings is general problem of Visual Studio (also if you use TwinCAT XAE Shell which is basically a Visual Studio 2017). There are lots of hints in the internet if you search for Visual Studio lost settings.
Hint: You can export and import your settings.
