Possible improve or bug on Distribute ToChain property
Hello all,
I'm developing a CmdHandler object, i need to have a internal elements as a library. On CPS my  library is an extension of my object and my object extends OpconCmdHandler.
For any reason in this CmdHandler the porperty distribute to chains is not available on unit. Why?  I though that there is no difference between types on ComdHnadler. Distribute to chain should be available on any CmdHnadler.
Thanks in advance.
I am not sure if I understand your problem correctly, so first some words about the DistributeToChains property:
  • The property is availabe in the Types tab at any child element of all project-specific FBs deriving from OpconUnit (also indirectly).
  • The property is never read from OOD/OSD files as it only affects project-specific SFC sequences, so the user should decide whether he wants to have references to the sub-struct.
  • With most objects (also the ones having InternalElements), the Unit FB is part of the library and not extended but only instantiated in the project. In this case, it is impossible to add the property. But in the same case, it is also impossible to create SFC chains, so the property wouldn't have any effect, anyway.
By the way, the DistributeToChains property is more or less obsolete since Control plus Studio 5.1: Since that version, all SFC sequences are automatically generated with a reference to the Unit FB (rUnit), so they can access all sub-structs of the unit without bothering about DistributeToChains.
In case this does not help you, I have some questions:
  • Where exactly are you missing the property and what seems to be different to a normal CommandHandler?
  • What's the nodeType of your object in the OOD file?
  • Does your object generate a project-specific derivation for the unit FB?
