PLC OpconUser vs. mPad NexeedUser
Our project has CX2020 with Control Plus V1 and later we bought mPad as a primary display. Now we have some issues related to Data Set Manager. HMI from mPad was not able to get type data files. After few hours I figured out the reason for that is on CX2020 is current user OpconUser but on the mPad we have NexeedUser. Bacause of this system is not able to acces \\PlcTarget\DataSetmanager share. After we tried to map share manually using OpconUser credentials it started to work and it works also after PLC restart.
My question is how to corrently handle this situation. Install older version of image to the mPad? Create OpconUser on the mPad? Anything else?
Control plus Studio allows you to change the user name and password of the existing users.
  • Create a dummy project with Control plus Studio 5.x.
  • Add an IPC target system and configure the hostname/IP address of your mPad.
  • Open "Remote connection to target device" in the context menu of the IPC
  • In the Credentials tab, check Change username and Change password and change the users back to OpconUser/OpconAdmin
