Hello BCI devlopers, I have a suggestion for OES copying function, I usually want to copy some reference from different projects, e.g. command handlers, units, subtrees, but if there is a little difference between their object version(please following picture as an example), I can't do it. That means I only can copy within the same project, if I want to refer to another one, I have to add all command handlers, units, subtrees manually, this makes me very unhappy.
I suggest make the copying function more useable,we can do it like this: if the version of used objects are compatible version, then we can copy it, currently, we can't copy it if only the last 2 digits of version are different.
