Object Browser 1.10, repository list is empty after installation (V1.09 before) + exception
After installing the object browser 1.10 (1.09 was running before) my repository list is empty and I receive the following exception when I try to edit the repositories afterwards (I should have clicked 'add repository'). I think the button should not be enabled when no repository is selected. When I select the default Nexeed repositories it gets disabled (which seems correct).
Is it possible to keep the repository list if a new version is installed?
Edit: also the STD list is empty. Keeping would also be very helpful.
Best reply by HugeGo
Sorry for the inconvenience.
We changed the settings path so it's aligned with Control plus Studio Settings. Therefore, we moved it from %AppData%/ObjectBrowser to %AppData%/Nexeed/Automation/ObjectBrowser (applies to log files and settings)
If you want to restore your settings, you can copy and paste them from the old directory into the new directory. This won't be necessary for the next version.
I will have a look into the misbehavior you mentioned for the Edit button.
