NexeedSchleichHighVoltTestBase V1.1.1.0 problem in SchleichHighVoltTestGeneralStruct
Hi Community,
I have a problem with the object mentioned in the topic.
The struct SchleichHighVoltTestGeneralStruct has a variable named MeasurementTime in the .osd file.
In TwinCAT, however, the variable of the same sturct was called TestStepTime.
This difference leads to DDL errors when using the Sturct as a result for MES because it cannot access the variable on the OPCUa interface.
Can someone help me?
greeting
René
Hello René, thanks for the hint!
This is indeed a mistake in the OSD file. We will fix this and publish the update with the next monthly release. If you cannot continue your work without the fix, I would suggest you correct the OSD file yourself for the time being.
