Hello together
I have an handheld scanner in my station and I need to have it always in the reading command.
I want to start the command read and wait as long as something was scanned, to analyze the data.
At the moment, I have to define a timeout for the max time of staying in read command. Is there a possibility to set up the object, that there is no timeout for the reading command?
I tried to build something on my own, with resetting the command before the timeout error is coming, but then I have a unreliable behaviour with the scanner, sometimes the first scan after resetting the command will be ignored, so I always have to scan twice.
Is this possible for handheld scanner?
Thanks in advance
