Nexeed Scanner need two scan cycles after Cancel
Hi,
I use the NexeedIPScanner-Peripheral with the NexeedScanner Object. It is working fine when after the read-command a code is received. Then, the next read-command is working ok. But if i cancel the unit (Execute to false), the unit is ready, but after starting reading command again, i have to scan two times. The first scan has no affect (unit is still in running and no OutCmd.Code), the second scan is working normal (unit in done and Code present). Does somebody have a solution for this? At the moment it is ok because the worker knows to scan 2 times 🙂
