When I configured an axis in OES, but compared to other projects, I found that the configuration item was missing(Target position).
Why is this? Where did I not set it up?
The folder "Target Positions" and the parameters within are only available when the Parameter "Positioning Mode (fixed Positions)" is set to "yes". In the verison of NexeedAxis you are using, this parameter is located in the "Services" folder. (In the current version, it would be in the "Modes" folder.)
