Language for objects and addons
Hello there,
i have a general questions about the language of some objects and addons.
In some cases there is already a translation. The translation will be only added when the language of the project has been set before the object is integrated in the project.
When i add another language to the project then the object will not update its translation. Is there another way to activate the translation again or do i have to integrated the same object again.
Another point is the language itself of some objects.
For example:
The tab for the different HMI pages got translated but not the HMI page itself.
Is this normal when the language is available but not for everything?
What is the easiest way to get the the translation of the page itself?
Thank you for some tips.
There is a small tool exactly for this purpose called TranslationUpdater. The installer is included in the Control plus bundle download in the folder Common\TranslationUpdater\V1.5.
With this tool, you can specify a folder with object definitions, and it will generate a .uni file (same format as the tranlation export from CpStudio) with all the texts missing a translation for a given language.
After completing the tranlations in the .uni file, you can use the second tab page of the TranslationUpdater UI to merge the translations back into the object definitions.
In case you are adding translations to objects provided by BCI, we recommend you to send us the result, so we can integrate the translations into the next official object version. That way, you don't need to merge the translations again after updating to a new object version from our server. Please contact the HelpDesk in that case.
