I would like to ask some implementation questions about PLC side, when use setup control of MES.
1.Should I configure the OpconXml in the DataSetManager ?
2.If select OpconXml, the DDL events will be sent by DataSetManagerAddon automatically during executing load data command or I need to create DDL events based on the xml file exported by Cpstudio?
3.if it is sent automatically, where can I find the structure 'DataAccessHead' and assign specific value, for example: type number
another question about public interface:
is it possible to use the xml and OPC UA at the same time? I mean telegram use xml, DatsSetManger use public interface
thank you~
