ctrlx PLC runtime 1.20.0 only available, but ctrlx works 1.20.0 is not available
Hello!
I have an issue, that 1.20.0 is the only available core runtime at object browser, but it cannot be downloaded from anywhere. I have 1.20.4 on my laptop, 1.20.5 is available at Rexroth collaboration room and I did not find any version on Nexeed data portal.
After exporting my control Plus studio project, ctrlx PLC engineering start with an error, as target device 1.20.0 is not installed. How can I have a compatible version for control Plus studio.
Thank you in advance
The version in the ObjectBrowser is only used for filtering objects that specify a minimum tool version of the PLC environment. It doesn't have any effect on your ctrlX project. You can just ignore the .0 at the end of the version number.
The project template used to create a new ctrlX project on the first export is brought by Control plus Studio. What version of CpStudio are you using? The template coming with CpStudio 5.8 should work with ctrlX Works V1.20.4 and V1.20.5.
