CODESYS gateway driver missing (in TwinCat3 ?)
Recently I got new PLC projects to work with, and right after opening the solution up, the following error message shows up:
The strange thing is, that with some of the projects, re-unzipping and restarting the laptop solved the issue.
However I got stuck with 1 project, where nothing seems to work.
-installed additional remote managers to 100% match versions
-cleared twincat and codesys Appdata/Roaming cache
-installed device descriptions, reloaded all standards and tried exporting again
-installed Codesys gateway driver (however, it was never installed, and the other projects started to work without this)
What can be the problem? Where can I find this plugin cache to delete/update?
