Whenever I configure the CG mode in CPS, after download and cold restart the PLC stops with an exception error. Unfortunately, I am unable to determine the exact cause as it refers to an object within. I believe I might have misconfigured some parameters. I have been going through the documentation, but it is still unclear where I might be going wrong.
If i delete everithing from CPS and Twincat I'm able to recover PLC to run mode.
Any help would be appreciated.
Thank you in advance for your help.
Csaba
