Hi comunity,
I can't download an HMI to an IPC. Everytime that i try it i get the same error:
The IPC is configured as TARGET_MODE=HMI
Versions: CPS5.1.0 - IPC 5.1 - HMI 5.1.1
What can be wrong?
Thasnks in advance
Hi comunity,
What can be wrong?
Thasnks in advance
You have to install certificate to target system.
After your unsuccessful connection you should find created certificate in C:\NexeedLocal\Certificates\RAT.Server\pkiserver\rejected. If I remember correctly the name of file should contain Bosch name of your computer. Move this file to C:\NexeedLocal\Certificates\RAT.Server\pkiserver\trusted\certs and try to deploy the IPC again. It should work.
Whole procedure is described in OES help. Look into section Project Creation > Target Systems > Activating the Control plus Studio certificate on the target system.
