CAB printer with Nexeed v4.11
Hi all and happy holidays,
I'm having a problem using the CAB printer peripheral with the Printer object.
The printer has an applicator attached.
I'm trying to print using FTP print. I'm able to send the file to the printer using the ExecAddon, and the printer accepts it.
Afterwards, I start the print command with all the replacement fields that I need to replace. Then, I start the "start" command to print and apply the sticker.
The sticker is printed and applied, but without replacing the fields. If I start another "Start" command, then the sticker is printer with the fields replaced.
This happens all the times. Meaning that I can only replace the fields on the second "Start" command.
I set the printer to "Print and Apply". The printer's screen says printing 1 of 1, then changes to 1 of 2 after the first print.
Is there any setting on the printer that I need to set (other than the Print and Apply) for it to be fully compatible with Nexeed object?
I'm using the CAB peripheral version 1.2.6.0 and the Printer object version 1.2.1.0
Thank you in advance.
Best reply by Jiri
I do not remember it exactly, bacause I dealt similar problem two years ago, but please check content of the last line in your printer file.
If the text A 1 is there, try replace it with A only. If it does not help, try to delete whole line.
